No power 4th gear
Old Sep 12, 2005 | 06:58 PM
cbracing17's Avatar
cbracing17
No power 4th gear
86 f-150. stock. Carter feedback carb. The truck seems to run pretty good through the gears but when i shift into 4th gear it runs bad. The motor spark knocks real bad and it looses speed. What should i try? It has an egr valve and all the emmisions stuff.
Cliff
Old Sep 13, 2005 | 10:45 PM
Johnboy_BoomerSooner's Avatar
Check to see if your spark advance is working... mine bogs down in O.D. but I've swapped the carb with a 2bbl and haven't changed the ignition yet so I have no advance right now. The engine runs fine, but power is pretty limited on the top end...and no passing power at all. Just an idea anyway, could be a lot of other things though.
Old Sep 14, 2005 | 07:58 PM
the peppermint's Avatar
the peppermint
switch to offy intake, four barrel, and different exhaust, you will have all the power you need
