Remote start/ Tach wire
Old Sep 11, 2005 | 11:47 AM
mach1466's Avatar
mach1466
Im installing a remote start system on my 2000 F150 4.6. I need to find the tach wire, its "supposed" to be a pink/white wire in a 3 pin connector under the air intake, infront of the engine by the fan. ITS NOT THERE and im going nuts. I have check every wire harness/ connector in that area let alone the entire engine compartment. Has any one else have problems finding this wire?? Please help!!!
Old Sep 11, 2005 | 01:50 PM
mach1466's Avatar
mach1466
Does anyone have any Idea??
Old Sep 11, 2005 | 03:15 PM
Franklin2's Avatar
Franklin2
The only pink/white wire I found was feeding the coil-on-plug coil for #2 cylinder. If the 4.6 is numbered like the old Ford engines, that would be the 2nd coil back on the passenger side of the engine.
Old Sep 11, 2005 | 04:02 PM
azjan's Avatar
azjan
Thumbs up
Try looking for a white wire with a pink stripe. My tack wire was above the master cylinder. 2001 ford E-150 5.4.
E350Traveler
Nov 1, 2009 09:55 PM
superv10
Feb 23, 2009 07:54 PM
allenle37
Jan 11, 2008 09:31 PM
F0rdF0rever
Jan 30, 2004 12:18 PM
