Clutch Linkage Repair
The shaft on my clutch linkage where the nylon bushing is, is badly worn. I purchased a new arm. The hole in the arm where it attaches to the rod from the pedal is smooth. I have not remove the old arm yet. Is it serated? Is the arm smooth by design so you can position it as needed?
Has anyone done this repalcement.
I do know that I am going to drill a hole for a cotter pin. That way, the bushing will not move around and wear out early, also it will help stop the wear.
ive got the hiem joint replacement on my trucks and i love it no more plastic bushing to wear out.
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
PRUSue
02-05-2020 09:20 AM
Boba Fett
06-29-2014 04:11 PM
