Clutch Linkage Repair
Old 09-11-2005, 09:08 AM
racenitro's Avatar
racenitro
racenitro is offline
The shaft on my clutch linkage where the nylon bushing is, is badly worn. I purchased a new arm. The hole in the arm where it attaches to the rod from the pedal is smooth. I have not remove the old arm yet. Is it serated? Is the arm smooth by design so you can position it as needed?
Has anyone done this repalcement.
I do know that I am going to drill a hole for a cotter pin. That way, the bushing will not move around and wear out early, also it will help stop the wear.
Old 09-11-2005, 10:54 AM
barebackjake's Avatar
barebackjake
barebackjake is offline
ive got the hiem joint replacement on my trucks and i love it no more plastic bushing to wear out.
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
Old 09-11-2005, 07:26 PM
chapguy's Avatar
chapguy
chapguy is offline
Sure wish I'd seen this before I spent all that time fixing mine at the beginning of the summer. That's a great item, barebackjake, thanks for bringing it to our attention! That is just awesome.
Old 09-12-2005, 09:11 PM
racenitro's Avatar
racenitro
My problem is that the Pin that the heim attaches to is too worn. That is why I bought the repalcement are.
By drilling a cotter pin hole, it will eliminate the movement that causes the bushing to wear rapidly. Wish Ford still made the replacement bronze bushing.
PRUSue
02-05-2020 09:20 AM
newr
1978 - 1996 Big Bronco
03-16-2015 07:48 AM
Boba Fett
06-29-2014 04:11 PM
rob6095
06-03-2014 10:11 PM
JimiLL
03-01-2014 07:17 PM
Quick Reply: Clutch Linkage Repair
