Mixing oil weight
Old Sep 10, 2005 | 10:15 PM
stretch five oh's Avatar
stretch five oh
Mixing oil weight
Obviously I wouldn't do this as common practice, but I didn't notice until it was too late. When I changed the oil on my 04 F-150 I put in 3 qts of 10w-40 and 3 qts of 5w-40. Do I need to drain it and replace it or should I be ok until the next oil change?
Old Sep 10, 2005 | 10:23 PM
kurthb's Avatar
kurthb
If it were I and it was regular cheap dino oil, I would change it. The 40W might be a wee bit thick for the clearances. Don't really think you are hurting anything but peice of mind.
Looks like you made 7.5W 40.
I run 0W30 in my 2 Explorer's and 0W20 in my 05 F250 V10....thin is in
Old Sep 10, 2005 | 11:54 PM
ford390gashog's Avatar
ford390gashog
drain it all out and use the correct 5w20 oil.
Old Sep 11, 2005 | 12:54 AM
ATCS2004's Avatar
ATCS2004
Yep, what he said. Drain it out and put 5-20w in it.
Old Sep 11, 2005 | 09:18 AM
Carguy1959's Avatar
Carguy1959
The thicker oil won't hurt your motor any. It will hurt your gas mileage. That in it self is a good reason to drain it and put the correct oil back in.....
Old Sep 11, 2005 | 10:17 AM
Powerdude's Avatar
Powerdude
The heavier weight oil will just shear, and sheared oil has a tendency to produce sludge. Sludge is not good for the engine.
Drain the oil at the first opportunity, and put the 5-20 oil in. Don't leave the heavier oil in there too long.
Old Sep 11, 2005 | 10:45 AM
Dazz's Avatar
Dazz
Obviously you have the ability to change your own oil. Drain the 5/10-40 and replace with 5-20. The greater weight could expand your engine tolerances to where the recommended 5-20 would not be as functional any more. Or, only some of the moving tolerances would be expanded and some not expanded leading to a problem where no weight of oil would be satisfactory.
Old Sep 11, 2005 | 12:01 PM
ChrisAdams's Avatar
ChrisAdams
I think I would change it, and not use either 10/40 or 5/40. I'm not worried about your clearances, but I would be slightly worried about your cold starts, as the synthetic blend 5/20 is going to hit your cam shafts a lot sooner than any thick oil or any non-blend oil.
These engines are a bit finicky on oiling the cam shafts on startup. That's mostly on the 5.4, but even the 4.6 calls for anti-drainback filters or the cam sounds like it is eating marbles on cold start.
With high quailty 5-20 oil cheap at Wal-Mart and other places, there really is no excuse to not take care of the engine.
Best of luck with it,
Chris
Old Sep 11, 2005 | 12:30 PM
stretch five oh
Thanks for the advice. Looks like I'm on my way to buy oil. While I'm at it, what's everyones take on synthetic and synthetic blend oil? Also can someone break down what the numbers mean? 5w=? 20=?
Old Sep 11, 2005 | 12:52 PM
ford390gashog
the best oil for your money is the mc 5w20 semi synthetic oil. walmart has it for 1.99 a quart. there is guys who swear by it it has been a flawless oil in tests i use it in my 03. also the oil filter is a fl8020s the s is important it has the silicone valve in it.
Old Sep 11, 2005 | 12:59 PM
ChrisAdams's Avatar
ChrisAdams
Yeah, what he said...
On the 5-20, skipping the actual true technical answer, (someone will post it)
the first w (winter weight) is the equivelant rate that it will flow at cold. The higher second weight is the weight. So think of 5-20 as an easy to pump cold oil that makes adequate pressure and thickness at any normal temp.
Someone will be along shortly to start the synthetic vs. blend vs. old style oil argument.
Meanwhile the oil the factory and dealer recommend (5w-20 synthetic blend) will treat you right.
Chris
