Auxilliary switch hook up
Old Sep 10, 2005 | 06:55 PM
D & R's Avatar
D & R
I have hooked up my auxillary lights but they don't seem to have any power. I have called all the local Ford dealers and no one can seem to help me. There are four wires on the engine side of the firewall that I have hooked up. Is there a specific fuse I need to install to make this work? Any help would be greatly appreciated
Old Sep 10, 2005 | 07:47 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
D & R
Welcome to FTE.
Check out our Guidelines:
https://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
Somone should be along shortly to assist with your enquiry.
See you around...
BigF350<o =""></o>
Old Sep 10, 2005 | 07:56 PM
matt1751's Avatar
matt1751
I beleive those are just pass through wires so you don't have to run anything through the firewall yourself,, there is no power to them,, you should be able to find the other ends under the drivers side inside the truck just hanging loose.. You would need to connect a switch and power source at that point to get power to your lights. Depending on the Amp draw on your lights and the trype of switch you use, you may need to wire in a relay as well,,
Old Sep 10, 2005 | 07:57 PM
Hayapower!'s Avatar
Hayapower!
If you've hooked up to the 'customer access' wires 'blue, white, black, red' they dead end running back to the fuse panel.. They are taped to the harness just behind the fuse panel and are 'tagged' customer access.. If you use these wires for powering a circuit, they'll need fused power fed to them.. They are for 'through fire wall' wiring/add on equipment.. If this is an 05-06 the upfitter wire leads will be behind the F/panel as well..
.....................HP.......
Old Sep 10, 2005 | 08:07 PM
jetact's Avatar
jetact
Do you have upfitter switches? If you do you will need to connect the pass through wire to the switch wire. I have used 3 out of the 4 switches and they work great.
Old Sep 12, 2005 | 12:44 PM
D & R's Avatar
D & R
Thumbs up
Just wanted to say Thanks for everyones help on my auxilliary switch hook up! Gotter done with all your help! Great site and I will visit here often!
