I get a noise like a new years noisemaker sometime when I let up on the throttle and touch the brake. Searching tells me that the noise is the IAC.
1986 2.9 Ranger AT
Thank you,
Rich
Does it happen only when you let up on the throttle, or do you also have to press the brakes? If you only hear the sound when you apply the brakes, then I wouldn't think it's the IAC. If what you are hearing is a kind of "woomp" sound, then I would suspect a sticky caliper or something like that.
