Wicked wheel prob
Old Sep 9, 2005 | 07:32 PM
troubledsol's Avatar
troubledsol
Wicked wheel prob
I just finished installing my ww and I have a bad leak coming from the manifold Y pipe everything seems good the clamp is tight and I left everything loose during tightening so what is the problem
Thanks for the help
2000 powerstoke
Old Sep 9, 2005 | 07:45 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to the FTE troubledsol
Did you mean the collector manifold in back or the five way manifold on the front side?
Old Sep 9, 2005 | 07:51 PM
toby5181's Avatar
toby5181
troubledsol I have the wheel on order. Anything you could let me know about the install to make it easier. I was going to try to install with the turbo on the truck
Old Sep 9, 2005 | 08:12 PM
troubledsol
I would highly suggest NOT removing the turbo at this point I have been working on this thing since 2 pm everything was together but I have a bad exhaust leak it is at the v band on the back of the turbo there is a 1/8 inch gap found this after complete disassembly bolt from turbo to craddle are loose downpipe is off and the thing just does not line up trying to loosen the flanges at the manifold and y pipe to see if it frees up this sucks
Any help please
Old Sep 9, 2005 | 08:17 PM
cookie88's Avatar
cookie88
FTE Emeritus
Is it hitting on the alignment dowl? Might just need to be rocked 1/8" one way or the other.
Old Sep 9, 2005 | 09:35 PM
HeatStroked's Avatar
HeatStroked
Here are some INSTRUCTIONS that may be helpful for those considering the Wicked Wheel installation off the truck.
Old Sep 9, 2005 | 09:50 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I have seen two versions of the Wicked Wheel and/or Superior Wheel installation instructions. Which is easier leaving the turbo on or taking it off, I ask this due to my own turbo surge problem.
Old Sep 9, 2005 | 10:49 PM
Kwikkordead's Avatar
Kwikkordead
I changed mine while the turbo was on the truck.
Old Sep 9, 2005 | 10:54 PM
RAMPAGE_F350
Kwik, as usual you are a plethora of useful info.
Old Sep 9, 2005 | 11:02 PM
Kwikkordead
With that little tiny post? LOL. I'll try and find a post that explains it a little better.
Old Sep 9, 2005 | 11:18 PM
RAMPAGE_F350
Well, you narrowed the decision making process. By the looks of it leaving to turbo on would be easier. I'm no expert, so I figured the less I have to take off my mule the less chance I have of putting it back on wrong.LOL I think black cloud has the "turbo on" instructions right? Or do you have an even better link?
Old Sep 9, 2005 | 11:23 PM
Kwikkordead
I just spent the last half hour searching with no results.
Wife is complaining so I have to hurry.
Get a 1/4 inch 12 point socket set with a swivel attachment so you can get at the bottom bolts. Then the job is do-able. You must remove the downpipe to hold the exhaust wheel in place or the whole assembly will spin and you'll never get the intake wheel off. Use a padded screwdriver to hold the exhaust wheel.
Old Sep 9, 2005 | 11:35 PM
RAMPAGE_F350
Thanks Kwik.
Old Sep 10, 2005 | 10:58 AM
toby5181's Avatar
toby5181
Just like RAMPAGE_F350 said thanks Kwik. I know which way O'm going now on the install. Ill try to follow BC DIESEL instructions. The wheel is not in yet I will keep you posted after the installation.
Old Sep 10, 2005 | 11:06 AM
Kwikkordead
Kudos to HeatStroked for this writeup.
It details removing the turbo from the truck, but you don't have to. It has some very useful pictures and tips for all that have never done this before.
https://www.ford-trucks.com/article/...tallation.html
