94 4.0l
Old Sep 9, 2005 | 07:20 PM
danxc's Avatar
danxc
Exclamation 94 4.0l
Hi all, i' m new in this forum and it' s very great...
I have an explorer sport with 4.0l auto 4x4, 145000km and i have 2 problemes
1: when it's cold it start very good but go to the road and the rpm is not stady about 200 or 300rpm up and down and when is hot no prob.
2: when is hot about +-2500rpm when i need more power it ping.
I clean the Maf and put a new egr and replace iac.
What wrong
Thank
Dan
Old Sep 9, 2005 | 07:28 PM
TigerDan's Avatar
TigerDan
Hi Dan, and welcome to FTE! Please take a moment to check out the guidelines, they will give you important information that you'll need when posting here.
https://www.ford-trucks.com/guidelines.html
The first thing I would do is to check the codes. Even if the Check Engine Light isn't on, the computer can still generate and store fault codes. You can purchase a code scanner pretty cheaply, or, some auto parts stores will check them for you for free, since they hope you will buy the parts you need from them. There is also a method you can use to check the codes with an analog (needle-type) multi-meter.
I am thinking, just off the top of my head, about the IAC (Idle Air Control) valve, or possibly the Coolant Temperature sensor. But those are just guesses, it's always best to pull the codes.
Old Sep 9, 2005 | 07:34 PM
danxc's Avatar
danxc
Thank for this advice, very apreciate...
for the iac, i edit my message because i mistape the name (icm...oups) to iac.
I go to check for the code even no light in the dash.
Thank
Dan
Old Sep 10, 2005 | 03:16 PM
mrshorty's Avatar
mrshorty
Another thing related to #2, make sure the intake manifold bolts are tight. They have a reputation for coming loose which leads to engine ping (also tends to leave coolant deposits on spark plugs especially #5).
Old Sep 11, 2005 | 07:24 PM
danxc's Avatar
danxc
Thank Mrs...i' ll check for that to
Dan
300-6 AUTO TECH
Jun 30, 2014 08:06 PM
romeodz
1997 - 2003 F150
Nov 4, 2011 09:58 PM
caterade
30
Oct 1, 2006 07:56 PM
caterade
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 27, 2003 06:12 PM
