Sponsored by: Real Truck
Fog light installation
Old Sep 8, 2005 | 07:29 PM
vito's Avatar
vito
I bought a 2006 F350 without the fog light option. Since then I ordered the Ford factory fog light set (5C3Z-15200-AC) online. I got the set with the 2 lights, the new dash switch assembly, 2 cables and some hardware and relays but no instructions. I need some help on where to connect the cables. One cable has the 2 connectors for the fog lights and 1 additional 4 pin connector. There are also some ring terminals in the cable. If anyone has any info or wiring diagrams I would greatly appreciate them or any other help. Thanks
Old Sep 9, 2005 | 08:15 AM
jaminjer's Avatar
jaminjer
I just received my kit yesterday. The part number is different but the equipment sounds the same. Here is the phone numbers from the bottom of my instructions. You should be able to call them and request instructions. 800-451-9245 and 800-275-7524. I could probably fax mine to you if that would help. My instructions are 12 pages.
Old Sep 10, 2005 | 07:22 AM
vito's Avatar
vito
jaminjer
Thanks for the reply and info. I will call the numbers you sent. If I have no luck I might need a copy of your instructions. Thanks again.
Old Sep 10, 2005 | 03:46 PM
jaminjer's Avatar
jaminjer
I just got mine installed. I took my time doing it, took me 5-6 hours. I think they turned out real nice. Took me a while to figure out the instructions from the pictures. I had to trim some of the plastic where the lights go with a dremel and didnt quite get the lights centered but over all I am happy with the install and the lights. Getting to the light switch wiring is tight, they dont want to pull out very far to be able to work with the harness's. I had a hole thru the firewall already for my alarm so it was easy to route the wires thru.
Old Sep 10, 2005 | 08:10 PM
97_Ex's Avatar
97_Ex
I installed mine today also, took me about 2.5 hours. It wasnt too bad and the results made it all worth the time!
Old Sep 10, 2005 | 08:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
is there any way to keep the fog lights on with the high-beams? i noticed today that mine go out when i turn the high beams on, and i dont like that.
rattleNsmoke
Jun 11, 2013 10:49 AM
tuffregal
Apr 7, 2013 11:38 AM
SuperMike
Jan 22, 2013 04:06 PM
slowjack
Escape & Escape Hybrid
Nov 28, 2011 04:51 PM
Patatoe1
Electrical Systems/Wiring
Dec 2, 2005 07:25 AM
