Taller Tire extra wear problems?
Old Sep 8, 2005 | 07:11 PM
DerangedPony's Avatar
DerangedPony
4wd Low
I have a 03 Ranger super-cab FX4 (4.0, 4.10 gears, Limited slip, 41,000 miles) and I was wondering if I went with a set of 265/75/16 tires, would they cause anything to wear out quicker like ball joints, u-joints, gears, or even the motor? Plus how much acceleration and fuel millage would I lose? Thank you for any help.
Old Sep 8, 2005 | 08:18 PM
Ken00's Avatar
Ken00
You didn't say what you have on there now but what you want to put on is close if not a stock size.
Old Sep 8, 2005 | 10:01 PM
DerangedPony
4wd Low
I have the stock 245/75/16 on the truck now which is like a 30in tall tire and I want the 265/75/16 which is like a 32in. tire which I heard is about the tallest you want to go without alot of trouble on stock height. Also, I do have a couple turns on the torsion bars.
Old Sep 8, 2005 | 10:32 PM
DerangedPony
4wd Low
Also, how wide are the stock 5-spoke wheels and would it be better to get 235/85 16 because they are a little taller, but not as wide to help with the rubbing problem (also cheaper)?
Old Sep 9, 2005 | 08:34 PM
Ken00's Avatar
Ken00
The 265s will be 1.2" taller and 0.8" wider, you should be fine, check out the link on tire sizes in the tech info thread at the top of this forum.
Old Sep 10, 2005 | 03:06 AM
littleme13's Avatar
littleme13
i have 265/75/16 bfg m/t on my 98 and i only notice rub on fulll turn and complete compression and thats very minimal seems to be hittin on a stupid piece of plastic on the inner fender that sticks out and im afraid to cut it off yet as far as ball joints and such ive had my bfgs for 40k and nothing has warn out yet and the tires are even just not gettin down to about half inch tread thats with driving everything you could imagine and some places i shouldnt no unusuall wear on anything
Old Sep 10, 2005 | 03:07 AM
littleme13's Avatar
littleme13
sorry thats on stock rims too
Old Sep 11, 2005 | 09:37 AM
valo's Avatar
valo
i don't think you will have any problems. I have that size on my truck. with no rubbing problems. My truck is a 4.0 2001 4x4
Old Sep 19, 2005 | 09:28 PM
frdrngrlvr's Avatar
frdrngrlvr
no problem
i have a 2000 4x4 off-road. before the 3"body-lift i had 295 75 16's bfg all-terrain no bs. the driver side rubbed a little when i turned left but that was it. now i have 285 75 16's kellys. i was always mistaken by the tire diameter size but they were pretty big. gas mileage went down. the speedo did not suprisingly. depending on tread pattern also has an effect on ride and mpg. i say go as big as you want and don't listen to tire guys because they always go by the book. everbody said it could'nt be done at stock ride height and i loved showing them it could.
ryanf250
Jan 8, 2015 04:14 PM
cabloom300
May 13, 2013 12:30 PM
06sonicsport4x4
1997 - 2003 F150
Apr 23, 2010 12:55 AM
2002 F350V10
Mar 11, 2010 09:08 AM
yooper00
Jul 12, 2006 05:13 PM
