1956 F-100, FE 390/C6 Radiator choice
Old 09-08-2005, 04:36 PM
tirediron's Avatar
tirediron
tirediron is offline
Looking for advice on radiator choice for my project F-100 pickup. It has a rebuilt, "mildly warmed" FE 390 with C6 transmission. Engine compartment uses the stock radiator surround. Only mods are Cordoba IFS TB front suspension and front tilt hood. I do not think either will affect radiator choice. I have available a seperate transmission cooler. No A/C (yet) but maybe in the future. My drivng will be at altitude, 4700', foothills, mountains on the east side of the Sierras. Would welcome others experience with radiators who's "footprint" might be suitable. I have seen like F-100's who said they used a Ford Country Squire radiator.
Bill
Old 09-08-2005, 04:57 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 4,079 Likes on 1,933 Posts
Welcome to the board!!!
When I was searching for a radiator for my 49 I used the links below, they allow you to scroll through databases of radiator data (sometimes a bit tedious) for different vehicles. You can generally get the dimensions of the core, brackets, etc, as well as the postion and diameter of the inlets and outlets. After I found a make and model that worked for my application I entered that info into the database of the local parts store and had them order me a radiator. (mine ended up being a mid 70's dodge truck)
Here' the radiator links;
http://discountradiators.com
http://www.radiatorbarn.com/
http://www.usradiator.com/
Then you can use these links for a local supplier (maybe)
http://www.partsamerica.com/Default.aspx
http://www.autozone.com/
I'm sure one of the wizards with a truck like yours will be along shortly to give up some advice also
Again, Welcome
Bobby
Old 09-09-2005, 03:10 AM
Goobzilla's Avatar
Goobzilla
Goobzilla is offline
I bought one from US radiator. Called them on the phone they asked where I needed the inlet & outlet and shipped it to me. I think some guys had some luck with the early 70's Ford truck radiators as well.
Ron
Old 09-09-2005, 09:05 AM
Earl's Avatar
Earl
Earl is offline
Welcome to the board tired. When you get a chance, make sure to read the FTE guidelines so you know what's appropriate for posting, etc. Then take a look at the sticky threads at the top of the forum and set up your gallery so we can see photos of your toy!
Old 09-10-2005, 12:10 AM
edsf100's Avatar
edsf100
edsf100 is offline
same set up as me. 56, 390. c6. i'm using a matsons stock 4 core with two electric 12" perma cool fans mounted on a shroud. located in sunny so cal. thermostat is 180 fans come on at 180 and temp is 180 to 205.
Welcome to FTE!
Old 09-10-2005, 01:54 AM
tirediron's Avatar
tirediron
Radiator for F-100
...thanks for the response. Can you elaborate on your radiatior choice! Do you have a model number I can give to my local radiator shop [LRS]. Had received info off net that a "Modine 522" would fit right in. Application said to be a "UPS Truck". LRS could not find it in catalog and he will call Modine tech rep Monday. I like the description of yours though, suggests more cooling capacity.
Bill
Old 09-10-2005, 09:00 AM
edsf100's Avatar
edsf100
edsf100 is offline
Here is Mattson web site. Give them a call. They do most of the Hot Rods in So Cal area and have a good rep. Very helpful. you can also get custom shrouds made here. Note: if this link doesn't work by clicking, copy and paste into your address line.
http://www.mattsonsradiator.com
Becky_is_a_66
29
07-04-2016 07:35 AM
Don Vito
23
03-01-2016 09:33 AM
F-250 restorer
05-01-2015 01:55 PM
BushyTea
02-15-2014 05:26 PM
abyars111
59
10-19-2013 05:43 PM
Quick Reply: 1956 F-100, FE 390/C6 Radiator choice
