1978 - 1996 Big Bronco
Trailmaster stuff
Old Sep 8, 2005 | 07:40 AM
cjbronco's Avatar
cjbronco
Trailmaster stuff
Has anyone run anything made by trailmaster? I've been thinking about it b/c im a lil tight on money right now but need new axle drop brackets for the superrunner steering. I want any feed back about them that ya have. Also, do the extended radius arms use new brackets or the stick ones just relocated?
Old Sep 8, 2005 | 09:54 AM
masseysbronco's Avatar
masseysbronco
all i know about is the radius arms, all the ones that i have seen relocate the stock brackets farther back, and come with drop brackets to extend them down. As you probably know the radius arm brackets are rivioted to the frame from the factory, so you after you drill them out to relocate the bracket your going to need bolts...
