Has anyone turbo-ed a 390 FE??
Old 09-08-2005, 02:00 AM
mustangsvo85's Avatar
mustangsvo85
mustangsvo85 is offline
I have a F-250 4x4 highboy with a 390 in it, and I know I read a hotrod article years ago about a twin turbo 390 FE (aluminum block and heads), but does anyone here have or know of a turbo FE. I would consider a supercharger too, but my experience is that turbos are a bit cheaper to set up. Anyone make kits, both supercharger and turbo?
Old 09-08-2005, 02:09 AM
BigF350's Avatar
BigF350
BigF350 is offline
There is some interesting info in this thread:
https://www.ford-trucks.com/forums/s...d.php?t=405218
You can fabricate most turbo's to suit. As for a blower that suits an FE, no doubt there are some around, just I am not aware of any.
Someone else may chime in though with manufacturers that make them.
Old 09-09-2005, 10:54 AM
skinsey's Avatar
skinsey
skinsey is offline
I'm almost done with mine...check the galleries...
Old 09-10-2005, 10:03 AM
perky's Avatar
perky
perky is offline
Skinsey What size turbo do you have on there it looks a little smallfor a 390.I had a H2E Holset on my sons 355 c.... truck.Had a smaller garret on it first way tomuch boost 21lb that is with the waste gate opening quick the boost was to hot.When I went with the h2e boost went down to 11 to 12lblot cooler boost and ran alot better alot less spark knock.Had a msd boost retard box on too.have that for sale put a snow water injection.When that comes on it feals like your hitting the nitirus alot cheaper window washer fluid.Watch your headers thats the way I made mine they will get cherry red at each port will get thin at those spots.You are dowing a good job. Keep it up.WE had the Holley projection the big one.Good luck
Dale
Old 09-13-2005, 09:59 AM
skinsey's Avatar
skinsey
skinsey is offline
More pics of the project. Almost done....These pics show the system out of the truck in a bench vise. it looks like the turbo is tilted but thats the way its in the vise. Should be done in 2 weeks. (will be on 7 day Alaskan cruise for one of those two)
Old 09-13-2005, 04:55 PM
discman's Avatar
discman
discman is offline
Pics look great! I can't wait 'till you fire it up. I'm thinking of the same kind of setup, so please keep posting those pics...
Old 09-14-2005, 08:10 AM
skinsey's Avatar
skinsey
skinsey is offline
I will make a short video of it when I fire it up. Then post a link to it here.
Old 10-27-2005, 01:46 PM
kord72ford's Avatar
kord72ford
kord72ford is offline
Can't what to see her goin
Old 11-20-2005, 01:35 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Any progress? I'd like to see what a turbo 390 will do. Oh, and what turbo did you use?
Old 11-29-2005, 02:56 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
wow, are u sure the exaust wont melt anything (the fan and electric water pump? ) just curious
Matt
Old 11-30-2005, 06:07 AM
skinsey's Avatar
skinsey
skinsey is offline
The Turbo is a Mitsubishi TD-06 (same as a T3-T4) This is the same turbo used on the GMC Syclone. Will produce boost easily to 20psi.
Old 11-30-2005, 06:08 AM
skinsey's Avatar
skinsey
skinsey is offline
I will wrap sections of the exhaust that will be close to anything critical.
Old 12-01-2005, 05:30 PM
DyceDesign's Avatar
DyceDesign
DyceDesign is offline
turboing the 390 should be fairly easy. Just have to fab your exhaust. In the spring I will be nuilding a blown 390. Useing a 8v71 supercharger on it and custom fabing the intake.
Old 12-01-2005, 11:27 PM
mhannink's Avatar
mhannink
mhannink is offline
wrap all of ur exhaust up to the turbo since heat is what helps spool it up not just air flow also i would use a deisel muffler or at least a straight thro so that theres not back pressure holding the turbo from spooling fast u would have enough from the turbo to save ur valves so thats not an issue
Old 12-06-2005, 03:37 PM
rusty70f100
I hope you guys are building up the bottom end a bit. Standard FE blocks tend to split around 650hp and 650ft-lbs. Truck blocks with higher strength metal alloys and extra main webbing tend to work real good. Look for a mirror image "105" where the "352" would normally be, or get me the casting number if you're not sure what you have.
Of course, ARP hardware and a main girdle never hurts either!
Quick Reply: Has anyone turbo-ed a 390 FE??
