Bronco II Ford Bronco II
next
Old Sep 7, 2005 | 11:03 PM
d2jc's Avatar
d2jc
next
changed the fan clutch, thermostat, and flushed the radiator and the temp gauge pegs at dead center.
The next thing to fix is the idle. It was sparodic, and I set the base timing which improved it considerably. still, as it warms up, the idle goes from smooth, to a little rough. Not enough to suspect a short in a plug wire, or a miss, but a little rough. Every once in a while to the point that it will stall when letting off the gas to shift gears at low speeds. Any ideas?
Old Sep 8, 2005 | 11:49 AM
Monty06's Avatar
Monty06
did you pull codes before doing all that or just started on what you though it might be
sandymane
20
Nov 13, 2016 07:41 PM
Tyler Labaume
Oct 21, 2016 02:16 AM
Delonge2002
1983 - 2012 Ranger & B-Series
Jun 8, 2016 01:00 PM
Christopher Layton
Apr 9, 2016 04:55 PM
collinrandle
16
Nov 17, 2015 01:13 AM
