drain valve
No offense...but, I did a google search and it took less time than it probably took you to type your thread / post.
Can also try www.dieselsite.com (admin note: do not deliberately by-pass the site software). This is where I bought mine and I got the retainer clip just in case.
The OEM plug uses a copper gasket that compresses after a few uses. Can always buy a new one for $1.00 - $2.00... but the Fumoto valve is slick!!!
I went without the nipple since it still drains easily and I did not want to hit it on anything. If you have 2WD, then go "no nipple".
Good luck,
I am more concerned with having to pull trash (grass, hay, brush, etc) away from it than having a clearance issue and busting it off.
In addition, I have been stuck a couple of times in my middle pasture...crappy General Tires and clay soil don't mix well...and I have wondered if I bottomed out if it would get the valve.
Almost ordered one today...decided to wait...again.
Wasn't Lamkin working on a FTE deal with those Fumoto boys?
To actually engage the valve to drain requires 2 motions, like you have to pull it toward you then move it to the side. As for actually hitting the valve on a rock or something, I have not had that happen yet and hope to not put my truck in a situation where this is possible, but it does not stick out much further than the stock drain plug.
In all seriousness, its just so shielded by the frame and front suspension that I don't see how it would be possible. Not to mention they are pretty solid little buggers...I would imagine it would take a lick or two to knock it off.
The valve is somewhat protected from the front, but anyone that is saying it can't break off must never go off road much. I think it is extremely vulnerable where it is located. It might not be vulnerable going forward, but if you are in reverse the valve is one of the lowest points in your drive train with exception to your rear end. I have seen logs etc bounce up and dent oil pains many times. Not a big deal usually, but hit the valve once and I think you have a serious problem. I'm also concerned about the ease of flipping the lever to drain as well. If you are always on the street and never in the woods, it's a pretty good gizmo with exception to the ease of flipping the switch. The two actions to open it can easily be circumvented by one fairly small twig hitting it at an angle. If you EVER come close to bottoming out or go through brush etc, forget about this thing. For those of you that still like the idea, definitely NO nipple. It's not necessary.
This is just my opinion after installing it. Take it or leave it.
That happened to me on the second oil change, go under there with your 19mm
wrench and a rag. Loosen the drain plug two turns, turn the copper gasket a half turn now retighten. wipe off the drip or two. DON'T OVERTIGHTEN
Note, however, that the oil should be changed at operating temperature.
I don't worry about knocking the valve off or it opening by itself, I think that there is more chance that the kid changing your oil at a dealership would forget to tighten the drain plug. The results are the same aren't they?
I carry the original drain plug in the truck so that if something should happen I have a plug. Wonder how long the engine would run if all the oil drained out? By the very nature of the PSD I would imagine that it would quit rather quickly, possibly before any serious damage had been done. Anyone want to drain the oil while the engine is running and give us a report?
One last thing if doing a Google search spell it correctly, it's fumoto not furmoto...
Dorf
For what it's worth. FRAM makes a similar item called the SURE DRAIN. You can find them at Wally's China-Mart. Don't know much about them, just my $00.02 ! THANKS
For what it's worth. FRAM makes a similar item called the SURE DRAIN. You can find them at Wally's China-Mart. Don't know much about them, just my $00.02 ! THANKS "
I had the sure drain on my gasser (5.4L) and I could have sucked it out with a straw faster than that thing drained. I plan on trying the Fumoto hoping it drains much faster than the Sure Drain.
I tried everything from the oil cap to the dipstick to eliminate any suction. It didn't help. I could watch grass grow while draining the 6 qts my gasser took. Immagine draining 13.5 qts out of the 6.0!
Anybody got any experience with the speed of the drain with the Fumoto?
Big
