Code says running lean
Old Sep 7, 2005 | 08:54 AM
mothra's Avatar
mothra
This is a 2000 4.0 4wd ranger. Started it this morning and it stumbled a few times at idle at initial startup runnning smooth as it warmed up. After driving 2 miles I noticed a check engine light. Pulled the codes and they read a lean condition in Bank 1 and Bank 2. Truck has 84,000 miles. I know it needs new wires and plugs. Any suggestions before throwing parts at it.
Old Sep 7, 2005 | 11:56 AM
Dave257's Avatar
Dave257
A Lean condition useally means a vac leak and the 4.0l's have a habit of leaking around the intake manafold. Make sure the intake bolts are tight and maybe think about a new gasket.
Dave
Old Sep 7, 2005 | 06:22 PM
mothra's Avatar
mothra
more information now
Check for a vacuum leak in the intake system. No leaks. Steady 22 lbs/inch at idel with appropriate throttle response.
Codes pulled are:
P0171 System to lean (Bank 1)
P0174 System to lean (Bank 2)
I am leaning towards the hot O2 sensor or the MAF as the problem. Any suggestions.
Old Sep 7, 2005 | 08:08 PM
Dave257's Avatar
Dave257
Do a search on p0173 in the forum search function and you will see several pages of this problem.
Dave
Old Sep 8, 2005 | 04:52 PM
mothra's Avatar
mothra
so I cleared the code to see if it would come back. All looks good so far. I plan to clean the MAF and test the O2 this weekend. We shall see how it turns out.
Old Sep 9, 2005 | 05:15 AM
aggyaggy's Avatar
aggyaggy
A hole in my exhaust just after the cats gave me these codes, I fixed the leak and the codes never came back. Just a thought.
Old Sep 10, 2005 | 07:54 PM
AlfredB1979's Avatar
AlfredB1979
That might be the case IF the downstream O2s are the problem, but the upstreams only measure OXY content in the exhaust.
If you aren't leaving out anything in terms of important details about your findings, you got lucky in your fix and guess.
mattymax
Dec 20, 2015 10:13 PM
pnp522
Modular V8 (4.6L, 5.4L)
Jul 15, 2015 04:40 PM
jasonhaysler
Jun 27, 2015 12:33 PM
mizzourover
2009 - 2014 F150
Apr 14, 2015 09:28 AM
fisherking
22
Apr 30, 2009 11:46 PM
