OK, so after a great deal of work, not all productive, I finally get the downstream O2 sensor out and install the new "BOSCH PRIEMIUM OXYGEN SENSOR", only to find the wiring is about 2" short. It won't reach the coupling.
What to do now? I hate to splice wires as I think it creates a weak point that might fail sooner than later.
Should I return it? Is there another brand that has the proper wiring?
Has anyone else run into this?
Help
Well, it seems that the only difference between the 15717 and the 15718 is the length of the harness. So I took the 17 back to one store, which was still out of stock on the 18, then treked off to the other store to pick up another 18.
