96 Econoline Reflash?
Old Sep 5, 2005 | 05:16 PM
Phantom's Avatar
Phantom
While checking out other problems I found that 96 Econoline 4.9s had a TSB for a computer reflash for Bank 1+2 lean codes and Mass air flow meter codes. I have an appointment at the local dealer to run a diagnostic on the truck to check for the reflash. Is there any way I can tell with scanners if this has been done? I have access to both Snap On regular scanners and the MODIS if I can tell myself it will save me $100.00 that the dealer will charge.
Old Sep 13, 2005 | 02:44 PM
reno94's Avatar
reno94
I dont know of a way with an aftermarket scanner , but if it was done by the dealer there is usually a sticker under the hood telling of any changes especially if it's related to emissions.
Old Sep 13, 2005 | 08:05 PM
Phantom's Avatar
Phantom
Thanks Reno, Ended up at the dealer they checked it all over. Tech said he noticed the TSB and pulled the software revision from the computer and it had all the updates. No vacuum leaks and everything else checks out, even the aftermarket "Reman." Mass Airflow Meter. Tech said could be partially clogged injectors.
49F1BIGBLOCK
17
Jul 9, 2012 09:46 AM
CanadianSmokie
May 27, 2009 07:53 PM
Automator
23
May 13, 2008 07:38 AM
fordfish
6.4L Power Stroke Diesel
Nov 7, 2007 07:27 AM
abendx
Computer Chips & Tuners
Nov 13, 2003 08:27 PM
