Sponsored by: Real Truck
Upfitter Switches
Old Sep 5, 2005 | 04:11 PM
PMBLU350's Avatar
PMBLU350
Upfitter Switches
Hi,
I just registered and about a month ago I bought a new F-350 (2005) that has four "Upfitter Switches" on the dashboard. The sales guy didn't know much about them, nor did he seem to care much. The service counter people looked busy when the sales guy gave us the 5 minute tour of the facility.
MY QUESTION:
I want to hook up my CB to one of these switches. Where is the connection that is operated by these switches? Do I need some "Ford" connector to "properly" connect to these switches?
I looked in the owners manual-no info. And Ford's official site search finds tyhe search words "upfitter swithes" but that reference does not show any details. It shows these as an option but no details.
Thanks in advance for the info,
Phil
Old Sep 5, 2005 | 09:05 PM
Dealford's Avatar
Dealford
Read This...
https://www.ford-trucks.com/forums/s...itter+switches
Hopefully it will help a little.
AL.
Old Sep 6, 2005 | 06:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome PMBLU350to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Also check this out
https://www.ford-trucks.com/forums/s...d.php?t=303583
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 6, 2005 | 02:17 PM
stlmo2's Avatar
stlmo2
Upfitter Switches
Remove the kick cover under your steering wheel to access the fuse panel.
Use a ratchet and 10mm socket, remove the (4) bolts securing the fuse panel. The 4 wires going to the upfitter switches are under the fuse panel, and marked. Switch 1 and 2 are 30 amp, switch 3 and 4 are 10 amp. Now would be a good time to add extension wires to the other 3 switches you are not going to be using at this time, so you don't have to drop the fuse panel again, unless you are going to hook up the AIC wire, which is located in a bundle of wires above the emergency brake pedal. Good luck.
Also check this out
