Sponsored by: Auxito
Gotta Lean
Old Sep 5, 2005 | 02:54 PM
FordFrenzy97's Avatar
FordFrenzy97
Gotta Lean
I have a 1998 F-150 and I noticed that the rear driver side of the truck is lower than the other 3 corners. I checked underneath and I didn't see anything that was bent or broken. I'm wondering if the shock is bad but I was told that shocks hold no pressure. Any suggestions would be appreciated.
Old Sep 5, 2005 | 02:58 PM
captain p4's Avatar
captain p4
How much lower is it?
If its just about an inch, or maybe a little less, its probably just the fuel in there. Do you have a full tank of gas?
How many miles on the truck?
Old Sep 5, 2005 | 03:23 PM
FordFrenzy97
Even on an empty tank it sits a good 2 or 3 inches lower. It has 200,000 miles on it.
Old Sep 5, 2005 | 04:14 PM
captain p4's Avatar
captain p4
It could be shocks, maybe the springs are worn out, or even something broken under there.
Someone else will come along that has more knowledge than me, but i'd go over everything under there again make sure something isn't broken.
Old Sep 5, 2005 | 07:27 PM
triton_2002's Avatar
triton_2002
Is it the body that's low or the suspension. Might be a broken leaf spring, any weird noises over bumps?
Old Sep 5, 2005 | 10:01 PM
steve(ill)'s Avatar
steve(ill)
i would guess the spring has taken a set, or broken a leaf. you will need to jack up the back and hang the wheels off the ground to see. might be time to visit the local junk yard. shocks do not normally carry any load, just dampen the bounce. i suppose you could add air shocks, but one side would have to have more psi to lift the truck. probably not a good idea.
Old Sep 6, 2005 | 06:04 PM
FordFrenzy97
thanks for all the help will try to check it out this weekend
