Drop pitman arm?
Old Sep 5, 2005 | 12:01 PM
MBBFord's Avatar
MBBFord
Question Drop pitman arm?
I know someone has to know this.
Are the drop pitman arms the same for the F-150s as they are for a F-250?
I've seen them listed as Ford pitman arm, with no real description, so would they work with a F-150 and a F-250???
Old Sep 5, 2005 | 05:33 PM
ivanribic's Avatar
ivanribic
Here's my disclaimer: "I don't know for SURE" but the drop pitman I'm using on my F250 is a Skyjacker arm advertised for the F150. Based on this I would say they are the same. Hope that helps.
Old Sep 5, 2005 | 05:38 PM
MBBFord's Avatar
MBBFord
Thanks, I've seen the advertised as a Ford Drop pitman arm, so I can get one from mark a. , but his was off of a F-250 and I wanted to use it on my 79 Bronco, which is the same as a F-150.
Old Sep 5, 2005 | 06:58 PM
ivanribic's Avatar
ivanribic
Should be good to go. And, btw, Mark is a standup guy. He's helped a lot of people on this forum out with parts. Tell him we said hi and to post up more often.
Old Sep 5, 2005 | 08:02 PM
MBBFord's Avatar
MBBFord
Will do, I'll try to get it from him somtime soon.
Thanks,
Matt
Old Sep 6, 2005 | 01:53 AM
74fordtruck's Avatar
74fordtruck
Just one thing to remember, the power assist in the highboys is a totally different setup too, so the pre 77 (?) f250's wouldnt be the same.
Old Sep 6, 2005 | 08:42 PM
MBBFord's Avatar
MBBFord
Mark has a 79 F-250, so should it(drop pitman arm) work on my 79 Bronco, which has the same everything as a F-150 ???
