Help- Rearend choice
Old Sep 5, 2005 | 11:37 AM
mouse777's Avatar
mouse777
71 F100, 87 CrownVic 5.0, AOD Trans, 31" dia tires and 27" dia tires, about a 3.5 rear. Engine lugs down bad @ 35- 40 in 3rd, and 50 or so in OD. Some one posted a formula for ratios before, I wrote it down and can't find it. Would appreciate any input, except I should be more organized and not lose stuff!!Thanx guys and girls.
Old Sep 6, 2005 | 06:20 AM
jowilker's Avatar
jowilker
Mouse the late 80s early 90s ran 3.55 rears behind 5.0Ls & AODs. Maybe you need to work on your tuning a little. A 3.75 rear ratio would work better. IMHO
John
Old Sep 6, 2005 | 02:38 PM
mouse777's Avatar
mouse777
Thanks Jo, Guess I better get into it from scratch again. I'll let you all know what turns up.
Old Sep 6, 2005 | 04:23 PM
71 Sport Custom's Avatar
71 Sport Custom
Mouse, Try this out. http://www.novak-adapt.com/knowledge/gearing.htm . It was sent to me to help me with a gearing problem. I think you can find the whole thred here https://www.ford-trucks.com/forums/s...d.php?t=317892 . Everyone was incredibly helpful in selecting gears. It seems like you might want shorter tires or lower gears. I'm running 30's with 3.73's and am very happy with them.
Old Sep 6, 2005 | 11:58 PM
gtex's Avatar
gtex
With the OD and 31s you can obviously get away with some more gear out back. If you're going for the best mileage, then your 3.55s are probably a good choice with A0D. If you want some more pep, look at some 3.73s or 4.10s.
Dandman1
6.7L Power Stroke Diesel
18
Feb 12, 2014 11:07 PM
diesel&coffee
Aug 9, 2013 06:33 PM
Fat_Tire
62
Oct 6, 2010 04:41 PM
DoorKicker
Jan 27, 2007 06:22 PM
4x4ranger01
1983 - 2012 Ranger & B-Series
Nov 23, 2003 09:56 PM
