I don't know why ferd put such little wipers on a nice large windshield like my aero has, but I replaced them with much larger ones and now I can see forever.
Ken
Ken
Are you SURE you had the correct size on to begin with? I just replaced the wipers on my Aero with the same size as I took off (22 inch/559 mm) and I don't think you could put bigger ones on. If you did, they would hang over the right side of the windshield or hit the top. You are correct that it does make a difference. Windshield wipers are like shock absorbers. They go bad gradually and when replaced, make a big difference.
If you replaced the 22 inch wipers with bigger ones, what size did you use?
I put a 24" on the drivers side and stock 22" on the passenger side, both teflon. Wife doesn't seem to care one way or the other. Remember it will only stick out one inch more on either end. On the rear wiper, I replaced the arm with OEM part and installed stock size teflon, works a 100% better.
As long as the wiper blade isn't wiping over the glass gasket you can go bigger I'm sure that over wiping will cause premature wear.
I remember when I replaced my stock original rear wiper with a Bosch I accidentally put the pin in the wrong hole on the blade and it was draping over the rubber gasket and not wiping properly.
Man that stock wiper was on there I felt like I was going to break the pin especially since I never removed a pin type wiper arm before I didn't know how much force to use. Luckily the newer wipers have a clip release so you just push in the clip and remove.
Me too, a parts store guy gave me the tip. Works great.
I replace mine every year and a half or so two years max as long as you don't use them in the winter when your windshield is iced (tears up the rubber which causes them to leave streaks when its raining) they should last about that long.
When I was in High School one of the guys made linear induction wiper blades for a Science project. The wiper was the armature, the field windings were all the way across above and below the windshield. The wiper blades parked themselves on the "A" piller on either side of the windshield. The really neat thing was the whole windshield was wiped, not just two arcs.
