tach install
Old Sep 5, 2005 | 09:29 AM
bedardrob's Avatar
bedardrob
tach install
I have a 1990 Mini School Bus . can I install a tach from a gas engine on it? If So how do I do it since there is no coil?
Old Sep 5, 2005 | 10:34 AM
PLC7.3's Avatar
PLC7.3
Diesels ours anyway use a Hall effect pickup sensor, located on the timing gear cover. That is where the IP is installed. There may be a 1" sensor in the cover, if there is then a dash cluster change to one with a tach installed "may" be a possibility.
DJOHNSTON78
Aug 16, 2008 08:46 PM
Big Red
Aug 24, 2005 09:51 PM
oft
Aug 7, 2002 02:50 PM
