1974 Starter Questions?
Old Sep 4, 2005 | 02:16 AM
rutang's Avatar
rutang
I just bought a 1974 Ford F250. Its a beautiful truck but it has a slight starter problem. It only happens every once in a while but, when you go to start it, the truck sounds like the starter is going bad. The previouse owner told me he replaced the starter and it still does it every once in awhile. You let it sit for a minute or two then it fires right up. What should I do? Replace the starter with a better one (if so what is a better one)? I appreciate your help!
Rusty
Old Sep 4, 2005 | 02:33 AM
ford390gashog's Avatar
ford390gashog
what sounds does it make. have you replaced the starter relay?
Old Sep 4, 2005 | 11:34 AM
subford's Avatar
subford
Sounds like the engine is full of carbon or out of time, this can rune a starter drive.
Old Sep 4, 2005 | 05:33 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
Could be a teeth on the flywheel/flexplate. Like gashog said, what about replacing that starter relay.
Make sure the connectors on the battery terminals are clean and tight.
Old Sep 4, 2005 | 06:16 PM
LxMan1's Avatar
LxMan1
If it only does it when the engine is hot, the timing could be a bit too high.
