D60 vs D70 rear ends:
Old Sep 4, 2005 | 01:56 AM
79Supercab's Avatar
79Supercab
I was hauling a 10' '76 Wilderness camper (3000lbs wet) and just upgraded to a 2004 10' Artic Fox camper (3300 lbs wet).
I have a '78 F250 4x4 Supercab with 460, C6, NP205, D44 front, D60 rear, 4.10s, 3400lb rated toyo tires & airbags.
What did the camper specials come with for rear ends? A D70? How much more carrying capacity does a D70 have vs a D60?
I'm not worried about spring capacity or frame strength. The frames between the 3/4 ton & 1 ton are very similar.
Ryan.
Old Sep 4, 2005 | 02:02 AM
ivanribic's Avatar
ivanribic
My truck is a camper special and came with a D60 rear end. I don't know the strength comparrisons in terms of how much weight one can handle vs the other but the shafts on the D70 are significantly larger than the D60 and the tube is 3.5" vs 3", plus a much thicker wall.
Old Sep 4, 2005 | 02:45 AM
79Supercab's Avatar
79Supercab
Interesting........I thought camper specials came with D70 rears. Learn something new every day
Old Sep 4, 2005 | 02:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
D60 - 5300#
D61 - 5300#
D70 - 7400#
Old Sep 4, 2005 | 03:03 AM
79Supercab's Avatar
79Supercab
Did the D70's come in the F350's? And did they only come in dual wheel configurations? Also aren't the studs 9/16 vs 1/2?
Ryan.
Old Sep 4, 2005 | 04:50 AM
ford390gashog's Avatar
ford390gashog
yes the d70 was for either single or dual wheel.
Old Sep 4, 2005 | 09:12 PM
FordPickup460's Avatar
FordPickup460
Dana 70's did come in F350's. You should'nt need to worry at all about pulling that camper, the Dana60 will definatly be able to handle a 3300lb trailer.
Old Sep 4, 2005 | 09:49 PM
ford390gashog
even a 9'' can do a 3300lb trailer. i do about 6k with mine 8k weight distributing.
Old Sep 5, 2005 | 01:57 AM
ivanribic's Avatar
ivanribic
Yes, they do use the 9/16 studs.
Old Sep 5, 2005 | 01:29 PM
wick246's Avatar
wick246
I don't remember ever seeing a single wheel D70 for sale locally - though I havn't combed the wrecking yards for them (local yards are very expensive). I have been watching for a couple of years now. May have to go with a Sterling.
Old Sep 5, 2005 | 05:41 PM
ivanribic's Avatar
ivanribic
Sterlings do tend to be more common but the D70's should not be too tough to find. I looked for several months here because I wanted a 70U with the smooth bottom. I couldn't find one so I finally just went and pulled a regular 70 out of a van. It will largely depend on you year of vehicles you're looking at, whether you get a 70 or Sterling.
Old Sep 6, 2005 | 03:03 AM
stegmst's Avatar
stegmst
entered in error
Old Sep 6, 2005 | 07:32 AM
79Supercab's Avatar
79Supercab
The reason I'm worried is I'll be hauling a 3300lb camper then pulling my early bronco on a trailer. So I'd imagine the trailer would have about 500 - 700 lbs of tongue weight. I'll be using a weight distributing hitch so that my help.
Are the spring perch dimensions the same between a van and truck?
Ryan.
