does new down pipe make engine noise louder in cab
installed new bullydog 3 inch downpipe had a rough time getting old one out wondering if I knocked something around to much or is it normal for the truck to sound differnt sitting still?
Is the full exhaust hooked up, or jus the DP??? Mine rubbed on the firewall a bit and that caused some noise to come through the floor, once that was fixed all has been quiet.
I had more noise when I first installed my dp. Found dp touching up pipe causing vibration. After that was corrected everything quieted down, good luck.
...Welcome to Ford Truck Enthusiasts!
Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
