Fuel filter change
Old Sep 3, 2005 | 08:06 PM
f350vince's Avatar
f350vince
Fuel filter change
I just changed my fuel filter and it came out black but the fuel was nice and green is that normal.
2002 f350 with 80000 miles on it. got it 3 months ago.
Old Sep 3, 2005 | 08:08 PM
Flinno18's Avatar
Flinno18
I did mine today too and the fuel inside the bowl was nice,clean, and green but the filter was nasty black.
Old Sep 3, 2005 | 09:10 PM
sdpj's Avatar
sdpj
thats normal
Old Sep 3, 2005 | 10:03 PM
Cool1996's Avatar
Cool1996
i just got my first diesel...i know where the filter is..but what do you have to do to get that plastic cap off to access it..i dont wanna break anything
Old Sep 3, 2005 | 10:53 PM
f350vince's Avatar
f350vince
I used a strap wrench, but it looks like you could use the filter wrench as well.
Old Sep 5, 2005 | 12:12 AM
Cool1996's Avatar
Cool1996
ok...that sounds easy
are the threads normal or left handed? and do you just lift it out and drop the new one in?
Old Sep 5, 2005 | 07:39 AM
Flinno18's Avatar
Flinno18
Threads are normal, and that's all it takes. Just lift up and try not to get fuel everywhere. If you click on the Aricles/Specs link at the top of the page, you can then click on Diesel and there is a step by step article on changing the fuel filter
Old Sep 5, 2005 | 08:26 PM
Roamineye's Avatar
Roamineye
I'd recommend draining the fuel out of the filter housing using the water drain. Then when you push the new filter on, it won't splash all over you like mine did the first time I changed it. Besides, you'll want to make sure there's no water in it anyway.
Old Sep 5, 2005 | 08:38 PM
Cool1996's Avatar
Cool1996
is the water drain the one they talk about in the tech article and the one i cant find?? hehe
Old Sep 5, 2005 | 08:42 PM
Roamineye's Avatar
Roamineye
I haven't read the article, but it probably is. Facing the engine, it's a little lever on the lower left side of the fuel filter housing. Don't forget to close it before you start it!
Old Sep 5, 2005 | 11:49 PM
LONEPINERON's Avatar
LONEPINERON
Also slide a piece of 5/16 hose up on outlet tupe so it wont drain down on front end and put drain pan or plastic bottle so you can see what you drained out. Aswell as not getting it all over the ground. Good luck
LPR
Old Sep 6, 2005 | 11:08 AM
JNygard's Avatar
JNygard
Its usually a bright yellow lever just move it to the right about 90 degrees looking down at it, towards the back of the engine.
Its mounted on the passenger rear side of the fuel filter.
Old Sep 8, 2005 | 07:50 PM
Cool1996's Avatar
Cool1996
well...i changed it today and it was easy..i couldnt find where you hook up the hose to drain it so it went all over my driveway..it runs a little better now i think!
Old Sep 8, 2005 | 09:09 PM
Flinno18's Avatar
Flinno18
Just so you know for next time. If you get underneath you truck and look on the left side of the motor just above the frame there is a little tube that terminates right there. I tried to hook a piece of 5/16 hose over it but it wasn't big enough to fit over the tube. I just make shifted a drain tube out of some electrical wire that was big enough, I had lying around.
Old Sep 8, 2005 | 09:18 PM
Cool1996's Avatar
Cool1996
sweet thanks
