351M distributor
Use some PB blaster on the joint and let it set for a day. When you try to loosen it use a pair of arc joint pliers on the housing down as close to the block as possible and turn it. If you are lucky you won't ruin the distributor.
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
