Climate Control Noise in Dash
Old Sep 3, 2005 | 09:34 AM
amkazen's Avatar
amkazen
Ok, my 1998 Expy with 4.6 and 150k miles now has another problem. I tell you, it never ends for me and my vehicles. Last week, the 4x4 quit working and approx. $850, two speed sensors, and shift motor, the 4x4 works again. I still have a slight whine when driving (not engine) I did not have, or at least did not notice before, but I have 4x4 again.
Now, there is a shoosing/hissing noise from under the dash. If the climate control switch is in any position besides off, the noise goes away. If you put the selector switch in the "OFF" position, the noise is there, and loud. You move the switch just barely away from "OFF", towards either of the two positions on either side of "OFF", and the noise starts to go away. I am thinking this is a vacuum problem but who knows?
Could it be a vacuum line leaking or come off?
Could it be the actual climate control unit went bad?
The a/c and heat still work just fine. All switch positions work fine, going from dash to floor, etc., etc.
Thanks for the input. My wife is driving it to the dealership as I type this for a diagnosis, but not to be fixed today, unless it is a hose or something simple like that. I wonder what they will tell her: $500 to fix it, probably.
Thanks.
Andrew
Old Sep 23, 2005 | 10:03 PM
Ultramagdan's Avatar
Ultramagdan
Did you find out what it was?
Old Sep 26, 2005 | 02:31 PM
msmarcus's Avatar
msmarcus
My wifes Windstar has the same deal going on. Please post what your problem turned out to be as I need a place to start on the fixing it.
Old Nov 19, 2005 | 11:02 PM
Punisher85's Avatar
Punisher85
Talking same noise here
I have a 1985 bronco II 2.8l and when I accelerate I hear a wooshing noise under my dash but i don't feel anything that could vibrate to make that sound and when i stop the annoying sound slowly goes away. I'm thinking it is the speedometer cable. I wonder if the speedometer cable turns or if there is a motor or something like that in the speedometer gauge? I would really like to hear what you found out. thanks
kornfanjoe
Feb 7, 2020 05:42 AM
ckirsch100
Dec 1, 2014 11:06 PM
kornfanjoe
Sep 20, 2013 06:38 PM
murph1
1997 - 2003 F150
Sep 26, 2008 09:45 PM
BCClements
2004 - 2008 F150
May 23, 2007 08:25 AM
