gear shift knob
Old Sep 2, 2005 | 11:04 AM
alienboy's Avatar
alienboy
gear shift ****
Hi I have a 2002 Ford Ranger Edge Manual Transmission and I want to replace the gear shift **** and I myself have tried screwwing it off like I've been told to and that didnt work so i was just wondering if anyone knew how to get it off oh and thanks for the help with my lift question.
Old Sep 2, 2005 | 11:58 AM
Dave257's Avatar
Dave257
Try heating it with hair dryer and pulling it off. Use rtv to glue it back on.
Dave
Old Sep 2, 2005 | 01:28 PM
kontai69's Avatar
kontai69
Originally Posted by alienboy
I want to replace the gear shift **** and I myself have tried screwwing it off like I've been told to and that didnt work.
The **** is press-fitted onto the shifter arm. The top of the shifter arm has splines (grooves parallel to the length of the arm). The **** also has splines on the inside surface. This is the reason why the **** can't simply be twisted off or unscrewed. You have to pull straight up on the **** to remove it. Alternatively, you can CAREFULLY slit the side of the **** with a sharp knife and pry it off.
Old Sep 3, 2005 | 01:22 AM
alienboy's Avatar
alienboy
ok thats cool thank you for the info now I know what to do but I have another question if the gear shift **** thats on my ranger now just pulls off how would I get the one that I'm buying to fit because the one that I'm buying screws on or would I just have to get one that can be press fitted or one that slips down onto the shifter arm?
Old Sep 3, 2005 | 02:33 AM
JD717's Avatar
JD717
I learned this the hard way pulling the 8 ball off mine. it wasnt exactly easy to get it back on there, nor was I exactly happy.
sailorman3
Nov 30, 2011 08:07 PM
hotwheel_2000
Mar 1, 2007 04:36 PM
r0n1n
Appearance & Dress-Up
Feb 14, 2006 07:35 PM
pcgold
Sep 20, 2001 05:49 AM
mandigo
Bronco II
Jun 25, 2001 09:41 AM
