charge the a/c
Old Sep 1, 2005 | 12:57 PM
demonfang's Avatar
demonfang
charge the a/c
my a/c and heat work but there is no refridgerant left in a/c. could someone tell me how to charge the a/c cause i want to do it myself. i have a 1992 ranger ext cab. also my dad has a 1996 ford contour that has a/c and refridgerant, but it only runs out from the vents by the windshield. could some one please tell me how i could fix it?
Old Sep 4, 2005 | 02:19 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The 92 uses R-12 so I'd suggest looking into a conversion kit (R-134a). You will also need at minimum a gauge on the suction side to determine the correct amount of refrigerant. Ideally you will have a gauge set. I'd suggest getting a book explaining A/C principles and how A/C works (and no, not a Haynes ). Charging and doing conversions is not rocket science, but there are a few ways a guy could get hurt.
On the 96, you probably have a vacuum leak or no vacuum applied to the HVAC system. Most Fords I've seen default to defrost under a no vacuum situation. Begin under the hood by checking for vacuum at the vacuum reservior.
TSFRD63
Jun 23, 2012 09:41 AM
Mudd460
2009 - 2014 F150
Dec 22, 2010 06:13 AM
EpicCowlick
May 24, 2004 02:59 PM
oldfordtrucksrule
Apr 10, 2003 08:43 PM
ford racer 02
1978 - 1996 Big Bronco
Apr 3, 2003 11:52 PM
