replacement engine
Old Sep 1, 2005 | 06:15 AM
budstoytruck's Avatar
budstoytruck
Smile replacement engine
how do you rate jasper engines??
my 3.0 is locked up #3 rod
Old Sep 2, 2005 | 12:55 AM
ford390gashog's Avatar
ford390gashog
well then you get stuck with a core charge as it is not rebuildable. they are good but very pricey. i think s&s is the same quailty and much cheaper www.rebuilt-auto-car-engines.com
Old Sep 12, 2005 | 11:04 AM
1bad71F100's Avatar
1bad71F100
autozone's long blocks are pretty good. i got a 302/.040 over last august, took the cam out and put a higher lift cam in, and added my acessories. the motor itself was just around $1000. it's a good solid motor. the only thing that went wrong was when i had about 200 miles on it, i decided i would get on it a little, well one of the rocker arms was a little loose and it came off the spring. i just knew i floated a valve or something. i have almost 5000 miles on it now and everything seems to be solid. good luck
Old Sep 14, 2005 | 08:58 AM
tomw's Avatar
tomw
There is a guy in PA, don't have it right in front of me, that will sell you any number of 3.0 Vulcans for $500 a piece. Out of Tauri or Sables. Good low mileage engines. I think that you could get one if these and turn it into a Ranger engine with little trouble. I have 225k on my '87 Sable, so considered a swap, but he's in PA and I'm in GA so it would be a long drive...
If you want, I can get the email from a text file somewhere on my computer.
tom
Old Oct 15, 2005 | 10:44 AM
deerhunter3814's Avatar
deerhunter3814
To answer your question in my opinion, the Jasper engines are an excelent reman. and they have a great warranty, that can be serviced at the shop of your choice. The only bad thing I have seen with them is the price. But you get what you pay for.
PSDx3
6.4L Power Stroke Diesel
Sep 2, 2013 12:38 PM
lilwrkmstr
1983 - 2012 Ranger & B-Series
Sep 15, 2008 06:54 PM
Tusc684
Modular V8 (4.6L, 5.4L)
May 12, 2007 06:16 PM
WXboy
Dec 22, 2002 01:53 AM
