Sponsored by: Real Truck
Brake issue with Tow Command
Old Sep 1, 2005 | 05:28 AM
JimRietz's Avatar
JimRietz
Either I have a problem with my truck or there is, perhaps, a design flaw in the system. Here's what happens:
As I'm slowly braking (1 or 2 bars on the Tow Command) and usually around 20-30 mph, something jars the truck (more on that later) and the brakes feel like I'm on ice and the TC panel stops at 1-2 bars no matter how hard I push the pedal. Releasing the pedal and re-applying pressure restores normal brake pressure.
This only happens when I'm loaded - well, make that the trailer has a full load on it.
There are two things that jar the truck to cause the problem. 1 - Hitting a bump with the truck (rear axle, I believe) and, 2 - the 2nd to 1st downshift - automatic - extremely harsh at times (let me know if you have this problem).
I never get a trailer disconnect alarm. I'm confident the trailer wiring or connectors are not part of this. I suspect the ABS is causing the brake limiting, although the ABS light never comes on. With the TC being limited at the current rate (1-2 bars), I can see there is a problem.
This generally only happens when I'm in stop & go traffic or going into a toll booth. It doesn't happen all the time - only when the truck is jarred. With 44k miles on the truck, I've been trying to gather as much information as I can. I have an early '05 and have heard (here) the newer trucks have an updated TC module - but for an unrelated problem with no trailer brakes at slow speeds - something I also experience.
Anyone else notice this problem? I've mentioned this a couple of times at my dealer, but they have never heard of it.
Jim
Old Sep 1, 2005 | 10:41 AM
NoMo's Avatar
NoMo
Sounds like when braking & hitting a 'bump', the ABS is engaging and causing the reduced braking. My '01 F350 had a similar issue and I was told that there was no problem. I just learned to drive/stop with the problem. Still, you shouldn't HAVE to do that.
I suspect there's going to be a "re-flash" in your future.
20powerstroke02
21
May 7, 2014 08:02 AM
Traveller76
Mar 16, 2013 08:13 AM
warrenrk
Aug 1, 2010 08:03 AM
vincewood30
All Things Towing
13
Apr 19, 2009 03:33 PM
