Aerostar Ford Aerostar
Seafoam
Old Aug 31, 2005 | 01:24 PM
Nappers's Avatar
Nappers
Seafoam
Wow!!
I used Seafoam in my 95 Aerostar and what a difference. I also removed the baffle from the airbox, another difference. 180,000 + miles. Original Tranny and Motor!!
You guys were right, that puppy smoked so bad that the neighbors went running. I followed the directions to the tee and what a difference, it idles so much nicer and take off is great and it takes hills so much better. A new car.
If you all haven't done it yet, do so, it will smoke bad and make sure you follow directions.
Thanks for the information you guys provide on this forum.
Later
Aaron
Old Aug 31, 2005 | 03:04 PM
VanGo's Avatar
VanGo
Which Seafoam product did you use and how much did you put in? I tried the Seafoam from O'Reilly Auto Parts. I put about 1/3 can which was more than it says to thru the master cylinder vacumn hose. I only got a small puff out the tailpipe. I don't feel any difference.
I was hoping to clean it out so I can run regular again without pinging!
Old Sep 6, 2005 | 06:56 PM
Nappers's Avatar
Nappers
Sorry VanGo, I was camping with the family. Lost a 25lb salmon but it was the best 25 minutes of my time there, fighting that big boy. hmmm, one pound per minute.......
Anyways, I used the can marked with "SeaFoam" (no sarcasm there really!!)http://www.seafoamsales.com/. I bought it at a Car Quest auto parts shop. The can is white and red. I used 1/2 a pint, or an 8oz in the little womans measuring cup is great, it is clear and I used the brake booster line. I reved it up high, inserted hose until it died and let it sit for a while then started it and ran it. It smoked very very bad. Just remember to clean the measuring cup thoroughly and put back unoticed. My Aerostar has just under 180,000 and it sure helped, it idles much smoother, climbs hills better, starts right up, and with the baffle removed on the air box, just seems to have a little more ooommmph to it. haven't had a chance to check mileage yet but I'm sure it's better.
Hope that helps.
Later.
Aaron
I'm going back in a few weeks to try the salmon again. If you see a salmon with a rig sticking out of it's mouth, let me know. Gold Beach, Oregon area up the Rogue River. 25lb'er bout 20 miles from the mouth.
L8R
Old Sep 6, 2005 | 08:38 PM
96_4wdr's Avatar
96_4wdr
put a whole can of Seafoam in it thru the brake booster hose, put a 20 oz can of Chevron Techron Concentrate in the gas tank, let her set 1 1/2 hours then out to the freeway and run her hard for 20 miles. did a great job on my 4L, more top end power accelerating and smoother running, gas mileage up 2.
great on the 25 lb'er fight, what a fish in fresh water, they never quit, fight until they rip the hooks out or break 30 lb test.
headed south on Oregon coast this weekend for the Redwoods. will throw a hook in the Rogue on the way.
Columbia has been hot for upriver bright Chinook to 45 lbs and fall Chinook fish are thick, silvers starting.
Old Sep 7, 2005 | 07:47 AM
VanGo's Avatar
VanGo
So you guys used the Seafoam Engine Treatment and not the Seafoam Deep Creep. I used the Eng. Treatment too but I only let it sit 5 minutes like the can said. I guess I'll try it again. Then I plan to replace the O2 sensor.
It still pings on regular gas. Worse with the A/C going.
Good luck next time with that salmon. Watch out for bears!
Old Sep 7, 2005 | 09:47 PM
Nappers's Avatar
Nappers
I used 8 oz but use the whole can or do two treatments. It worked for me quite well.
Yeah, have fun dropping a hook. I plan on going back in a couple of weeks or so.
L8R
Aaron
Old Sep 7, 2005 | 11:32 PM
Bear River's Avatar
Bear River
Former ******
If you have a 3.0, make sure the ignition timing is correct, as that could cause pinging too.
ajonesnv
13
Oct 5, 2013 10:04 PM
dyhrdford
Oct 22, 2010 08:29 PM
dirtballer
47
Apr 16, 2009 10:49 PM
msgtg
West Virginia Chapter
Feb 1, 2009 06:23 PM
makthenif
3.8 & 4.2L V6
Apr 17, 2006 04:40 PM
