Sponsored by: Real Truck
05 SD Ford gearbox fix question
Old Aug 31, 2005 | 11:54 AM
ag-ford-4x4's Avatar
ag-ford-4x4
I saw a post that had a broadcast message about a noise coming from the steering column or gearbox when turnning left. I was wondering what kind of 'noise' this is and what it sounds like. I have a noise that you can feel in the steering wheel, tire, and tie rod (as far as i can trace it). It only does it to the left while standing still, and it only does it when you turn it fairly quickly, if you turn it slowly or are moving, it never makes a noise. Havent had time to have it looked at and i was wondering if it was a lubrication thing. It makes a distinct low pitch squeek or chirp, and if you turn from lock to lock (left) it may make this sound twice with steering wheel rotation.
Any ideas?
Old Aug 31, 2005 | 02:11 PM
ridered29's Avatar
ridered29
I posted the thread you are referring to. Mine sounded as if it was coming from the steering column as well ? The service department said alot of things including there was a TSB on this exact thing. They replaced- moved- tightened- and loosened to the point where I was going to go to the lemon law. The last thing they claimed they did was replace the steering box. I picked up the truck last Friday and it made one odd noise and hasn't made one since. I will continue to monitor the steering but they seem to FINALLY have it fixed.
Old Aug 31, 2005 | 02:44 PM
ag-ford-4x4
but what did it sound like? What conditions did it do it under?
Old Aug 31, 2005 | 05:19 PM
FortyFords's Avatar
FortyFords
You should edit your post to state Steering Box question.
Rich
Old Sep 1, 2005 | 09:09 AM
ag-ford-4x4
i dont have an "edit" button. :/
Old Sep 1, 2005 | 09:54 AM
ridered29's Avatar
ridered29
To me it sounded like it was low on fluid- the pump squels or groans. Only did it turning left. They replaced the drag link, ball joints, power steering hoses, power steering pump, and finally the steering box and that is when it quit. I still am not confident they knew what they are doing. I initially thought it was in the steering column, but it wasn't. Hope this helps!
Old Sep 1, 2005 | 10:40 AM
ag-ford-4x4
When you were turning left, was it a constant groan or just a brief groan as you went from right to left?
Old Sep 1, 2005 | 03:09 PM
ridered29's Avatar
ridered29
Just a groan in spots, never constant- What has the dealership said?
DigitalCrossbow
Nov 27, 2014 02:51 PM
bbender85
Mar 18, 2014 11:54 AM
51frrdtrk
Dec 16, 2011 07:56 PM
5.4L to Freedom
Feb 13, 2011 03:55 PM
orthogod1
Jul 12, 2007 05:57 PM
