3 on the tree with PS ??????????
Old Aug 31, 2002 | 10:23 PM
78f250lj's Avatar
78f250lj
I have a manual 3 on the tree. Can I convert it to PS? If so, what would I need?
Old Sep 1, 2002 | 02:03 PM
78f250lj's Avatar
78f250lj
Anybody?
Old Sep 1, 2002 | 02:13 PM
Ford79's Avatar
Ford79
Most likely you will need a P/S box, P/S pump and brackets and all the lines. I'm not sure if the tie rods and all the steering components are the same for a non P/S equipped vehicle though. The easiest way is to find a donor truck to get all the parts from.
Old Sep 1, 2002 | 08:06 PM
evans's Avatar
evans
You also need a P/S 3 spd. steering column. They are more difficult to find than the automatics.
Mike
Old Sep 1, 2002 | 08:30 PM
otto's Avatar
otto
He already has the 3 on the tree column, i would say the ps box and pump/bracketry, and the lines
Old Sep 2, 2002 | 09:30 AM
ecarter50's Avatar
ecarter50
the steering shaft can be changed in the column to a power one.
Old Sep 2, 2002 | 10:43 AM
78f250lj's Avatar
78f250lj
Does the PS shaft have to be from a PS 3 speed column or can it be from a PS auto or a 4spd PS ?
Old Sep 2, 2002 | 12:04 PM
Jimbare's Avatar
Jimbare
all alone in the world
it can be from any of them. the shaft is the same as long as it is power steering.
Old Sep 2, 2002 | 12:40 PM
fomocoloco's Avatar
fomocoloco
i have the correct steering column in a 1978 parts vehicle. power steering , 3 speed on the column. good condition with wheel etc. thanks.
Old Sep 2, 2002 | 02:52 PM
loren1959's Avatar
loren1959
