What is a good tire / lift combo size?
Hi all! I've seen a bunch of "whats the largest tire I can fit ....", or "what size lift do I need for tire size xxxx .....". I've read the FAQ, and seen recomended tire size / lift needs.
But what I need are some good recomendations. I want a good tire size / lift combination for a daily driver, that will do some off roading. I don't want to get so high that I'm top heavy. In jeep TJ world, I was comfortable with 4.5 inch lift with 35" tires. 8" in 38's was too high for the TJ. BUT, I have some idea that height isn't as big an issue in my 2003 F250 as it was in the little TJ.
Do you all have any good recomendations? Should I go with a 6" and 36? Is an 8" with 38"'s starting to get too high? Or is 8" really nothing on these trucks?
Thanks for any info!!
Originally Posted by fishmanndotcom
we need to know what vehicle and what kind of trails do you hit and what kind of tire (all terrain dedicated mud tire rock crawlin tire) you want
i run a set of 35's on my powerstroke and no lift and i couldnt ask for a better combo!
-cutts-
-cutts-
I've got a 2003 F250SD XLT FX4, 7.3 diesel.
Thanks!
ok well, like i have mentioned before i love my buckshots and so far they have lasted a long time! you might look into tsl ssr's as they last a long time as well
for a daily driver might i suggest 35's maybe 37's. this way you still have a decent height but you can still get in and out of the truck easily and with 35's you shouldn't need more than 1-2" of lift (or a leveling kit)
thats just my opinion
here's what my powerstroke looks like with my 35's
-cutts-
-cutts-
Here is my '04 with 6" lift and 36" TSL Radials. If you go 8" you can get 38's.
https://www.ford-trucks.com/user_gal...&albumid=16708
If you are gonna off road hard and don't want to trim the valance or shim the bumper, get 35's. I had to trim the valance slightly and put the draw-tite receiver behind the front bumper to space it a little. 37's are a tight fit on 6" and you may rub the inner fender well. I wouldn't go 37 on 6" lift unless you are only gonna do some light off-road.
Good looks on an SD is 4" with 35's, 6" w/ 36's, or 8" with 38's.
f350rebel7788
47
09-27-2013 09:17 PM
Tepot
09-15-2003 12:13 PM
