Power lock button don't work
Old Aug 30, 2005 | 07:37 PM
fiddler5.0's Avatar
fiddler5.0
My driver’s side power lock button doesn’t work when the door is wide open on my 1997 Explorer Limited. It does work when the door starts to close. I suspect a broken wire were it flexes. Has anyone taken apart that rotary cable harness between the door & body? Do I need a new harness? Thanks Fiddler5.0
Old Sep 8, 2005 | 01:06 AM
LV Dan's Avatar
LV Dan
Many have taken the rubber boot apart to fix a broken wire. If you can isolate which one is the ground wire, that is what most people say needs repair. Although I am not sure why the ground wire is more likely to break than any other. I've not actually taken mine apart, but I would think it would be easiest to replace the right wire than try to fix it or replace the whole harness.
Old Sep 9, 2005 | 01:03 AM
aquanaut20's Avatar
aquanaut20
had the same problem, pulled down the rubber boot, found the broken wire fixed it and windows and locks work OK.... take the first step, it wont bite
