Sponsored by: Real Truck
F350 Rear blocks?
Old Aug 30, 2005 | 09:15 AM
gimp419's Avatar
gimp419
F350 Rear blocks?
I'm getting ready to change out my rear blocks on the 01 250 for a little lift. Just wondering if anyone had the Ford part numbers for the 4 inch F350 blocks and u-bolts. Thanks I'd really appreciate it.
Old Sep 1, 2005 | 08:02 AM
gimp419's Avatar
gimp419
Surely someone out there that's done this conversion knows the part#'s.
Old Sep 1, 2005 | 08:25 AM
sgthawkusmc's Avatar
sgthawkusmc
Have you tried the search feature?
Old Sep 1, 2005 | 10:41 PM
gimp419's Avatar
gimp419
I tried the other day but it was down. I'll try again, it's kind of one of those things that is time consuming to look for on here. Just thought that since it's such a common swap someone would have the part #'s handy. Oh well I'll do a search and see what comes up.
Old Sep 2, 2005 | 04:49 AM
dmp437's Avatar
dmp437
If you want the original Ford blocks go to powerstrokeshop.com and order them online or give them a call. Remember to use new U-bolts & nuts when changing the blocks. Since you're changing the U-bolts because of the lift blocks, now is a good time to make sure your truck is level, side to side. Part it on a level section of concrete and measure to the top the the wheel wells. If it's not equal Ford has a 3/8" shim kit just for t his purpose, to even it out.
Old Sep 2, 2005 | 12:46 PM
warmdye's Avatar
warmdye
I can't find anything on that powerstrokeshop.com.
Old Sep 2, 2005 | 06:49 PM
GMtoFord's Avatar
GMtoFord
Im wanting to do the same as you are,F350 blocks in the rear and a 2.5 daystar lift in the front....
Old Sep 2, 2005 | 09:37 PM
Dave Sponaugle's Avatar
Dave Sponaugle
E5TZ-5598-A for the blocks, cost about 40 dollars per back in Jan, this year.
I had custom 5/8" x 16" U bolts made at Fleetpride because I have lots of springs under mine.
They were only 13.95 each for four.
Old Sep 3, 2005 | 07:20 AM
gimp419's Avatar
gimp419
Thanks for the help guys it's greatly appreciated!
Old Sep 3, 2005 | 07:48 AM
Wrenchtraveller's Avatar
Wrenchtraveller
Some shops that do mainly suspension work will have take offs they sell cheaper than new. Many guys lower their trucks for 5th wheel towing.
Raymond
Ford Truck Parts for Sale
Mar 28, 2013 06:26 PM
Raymond
Mar 8, 2013 06:58 AM
ad326
Mar 25, 2010 05:12 AM
F3fitty
32
Mar 19, 2010 12:39 AM
high ho silver
Mar 5, 2005 09:39 PM
