front brakes dragging
Old Aug 30, 2005 | 12:12 AM
Truckmano5's Avatar
Truckmano5
I just replaced the master cylinder and brake booster on my 78 f250 w/dual calipers after my front right brake has been dragging. Now both front brakes are dragging with the front right still dragging more. What could cause this?
Old Aug 30, 2005 | 01:16 AM
tjay460's Avatar
tjay460
I read a thread somewhere in here about an adjuster rod between the booster and the master cyl. I wonder if the master is slightly activated all the time? Also could be brake lines failed on the inside, Corroded caliper slides or the slides are just dry and sticking, holding the inner pad tight to the rotor all the time.
Old Aug 30, 2005 | 12:20 PM
1975Ford's Avatar
1975Ford
You will need to remove the two nuts that hold the master cylinder. On the Power Booster, behind the master cylinder, there is a rod, at the end of the rod is a screw.
From the power booster to the tip of the rod it should measure anywhere from 0.985 inch to 0.990 inch.
RJB71
Oct 9, 2014 12:29 PM
78 & 87 Super Cab
16
May 11, 2013 08:02 PM
Stangrcr1
23
Aug 19, 2012 10:44 PM
rick52
Oct 25, 2011 08:42 PM
AKfordtruck
Jul 29, 2010 05:41 AM
