I have an '85 Bronco, I am not getting power to the back lock to roll down the back window. I plan on wiring my own switch in the dash but i dont know what i should take power from for the switch. any ideas?
the switch on the heat control dose not work at all, I am looking for key on power only. That is a good idea to re-wire the old switch and by-pass the old wiring, then just replace the switch that is in the heat controls, I suppose I just need to play around with it some more and try to find out why the key dose not have power.
