Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
compressor pump
Old Aug 29, 2005 | 07:05 PM
sdetweil's Avatar
sdetweil
compressor pump
Anyone ever thought about replacing their compressor pump with something like this? Pump.
I see that campbell hausfeld and eaton sell compressor pumps in this same range (Eaton)
this could give me about 30% more air at 90psi.. 10->13
Sam
Old Aug 29, 2005 | 07:48 PM
Ford_Six's Avatar
Ford_Six
You need a 5hp motor to run that, not one of those 5hp peak motors.
Old Aug 29, 2005 | 09:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
I am sure the motor in your consumer grade compressor is pumping all the air it can. It takes real power to compress air. Some of the ratings on those replacement pumps are misleading also.
Old Aug 30, 2005 | 12:21 AM
fixnair's Avatar
fixnair
Smile
Torque is right! You also have to make sure when comparing CFM ratings that they are at the same pressure AND either "Delivered" or "Displacement. Compressors are not 100 % efficient. Delivered air is roughly 70% of displacement air. Good compressors are somewhat more than 70% and poor compressors are somewhat less than 70%. Good luck with it
Old Aug 30, 2005 | 02:19 AM
ford390gashog's Avatar
ford390gashog
i have a old 5hp compressor and it says 50 amps on it. i think the rule is 10 amps for every 1 hp
Old Aug 30, 2005 | 03:22 AM
Torque1st's Avatar
Torque1st
Posting Legend
This is some info I have posted before in old archive threads:
The following values are taken from the catalog of a major manufacturer of high efficiency industrial motors for compressors. They will more closely resemble the values you should see on motors on high quality compressor units.
Single Phase Alternating Current Motors Full Load Current in Amperes:
HP - 115V - 230V
1 -- 16 - 8
1.5 - 20 - 10
2 -- 24 - 12
3 -- 32 - 16
5 -- 42 - 21
7.5 - n/a - 33
10 - n/a - 44
You can see that efficiencies increase as motor size/HP increases.
(Lower efficiency motors would have higher nameplate amperage ratings.)
To make things more confusing some retail manufacturers seem to "calculate" their SCFM ratings based on displacement and rpm. Commercial manufacturers actually test their units or use tables supplied by the pump manufacturer based on testing.
