MAF or other?
Old Aug 29, 2005 | 06:16 PM
pilot815's Avatar
pilot815
MAF or other?
I have a 2001 Sport Trac, that is indicating lean o2 censors. So i replaced all censors, and still didnt fix it. So i exchanged all them under warranty, and it still does the same thing. Reset computer too. Now the engine pulses at idle. It sometimes idles under, and sometimes has trouble idling. The other day as i was stopping at a stop sign, The engine died. So i started it up, no big deal. Today i was slowing down to make a right turn, and as i started to try and turn, i noticed i had no power steering, and the engine had died. The engine slows a bit when brakes are used. Any ideas?
Old Aug 29, 2005 | 06:56 PM
vicv's Avatar
vicv
IAC valve can cause this problem.
Old Aug 29, 2005 | 07:12 PM
pilot815's Avatar
pilot815
Ok, found it under the hood. Is there a way to test it, dont really want to go out and spend the $60 if its not gonna help any.
Old Aug 29, 2005 | 07:36 PM
bulldog3531's Avatar
bulldog3531
there is a sticky at the top of this forum on how to clean and test the iac valve
Old Aug 29, 2005 | 10:47 PM
pilot815's Avatar
pilot815
I went ahead and cleaned the MAF and IAC. The IAC was very dirty so i hope this helps, didnt have a chance to test it, but i will soon.
Old Aug 30, 2005 | 11:17 AM
pilot815's Avatar
pilot815
Ok i got under the hood again, and found a vacuum leak i didnt see before. There is a half inch (inside measure) elbow on the front right corner of the intake manifold that connects two lines that run around the manifold, that had a large crack in it. So i went all over town, and nobody carries the part, but ford does. The catch is they dont have just the elbow, i have to order the whole line that runs up the right side of the manifold. So a $2 part is gonna turn out costing $32. O well, gotta love ford right?
Old Aug 30, 2005 | 02:15 PM
bulldog3531
Have you tried a dealership? or maybe even a junkyard usually they have a few explorers in there and you can get the part if it don't look to bad. Just a thought.
Old Aug 30, 2005 | 02:24 PM
pilot815's Avatar
pilot815
Yeah the $32 price was the dealership. It actually turned out a little less than they had told me. It came out to $27 with tax. Took 2 hours to get from another dealer in another town. Installed in 5 min. Just took for a drive, and it idles better, and feels more powerful, and hopefully better mileage. Took a short trip on sat, and got 12.5 mpg on the highway. ouch! hopefully its better now. Thankfully gas here is still $2.33 a gallon. The junkyards down here, are short on explorer parts, and they usually arent that great especially after sitting in the sun, the rubber parts arent good at all.
Old Aug 30, 2005 | 06:51 PM
bulldog3531
Glad you were able to get your truck fixed. I wish gas was $2.33. Today it went to $2.79 a gallon.
Old Aug 31, 2005 | 10:23 PM
pilot815's Avatar
pilot815
We hit $3 today. This sucks. Diesel was $2.56, i was really wishing ford put a small diesel in the sport trac when i saw that.
Old Sep 1, 2005 | 06:23 AM
bulldog3531
we hit $3.00 some places more. But 90% of our fuel comes from the gulf coast. so some areas are running low and don't know when they will be getting more.
