pip sensor replacement question
Old Aug 29, 2005 | 02:11 PM
neoflee's Avatar
neoflee
Exclamation pip sensor replacement question
Do i need to remove the dizzy to replace the pip, I dont own a vice or pully to pull of the drive gear. I just mover here to Beatrice Ne. and dont know anybody who could help. Jon
Old Aug 29, 2005 | 02:24 PM
andym's Avatar
andym
What motor & truck? You generally don't need a puller to get the dizzy out. Just get the hold down bolt out of the way and it pulls right out. Of course, you'll need to set the timing after you put it back in.
Old Aug 29, 2005 | 02:32 PM
neoflee's Avatar
neoflee
the pip sensor is inside the dizzy cap, I would like to replace it. its an 87 f150 fi302
Old Aug 29, 2005 | 03:53 PM
subford's Avatar
subford
It depends on what Ignition System you have, if you have a Duraspark II then NO, you do not have to remove the Distributor. If you have a TFI Ignition System with a Universal Distributor then the answer is YES, you do have to remove the Distributor and remove the gear.
Old Aug 29, 2005 | 04:03 PM
neoflee's Avatar
neoflee
how do I know which I have, will you explain how to tell the diff?
Old Sep 1, 2005 | 07:09 PM
neoflee's Avatar
neoflee
its an 87 f150 fi 302 , but the pip has a ring that goes around the shaft, i think any ideas?
Old Sep 1, 2005 | 07:40 PM
subford's Avatar
subford
Sounds like you have a TFI. The TIF has large plug that plugs into the side of the Distributor. The Duraspark II has wires coming out right under the cap and a round plug about 6 " away.
Old Sep 1, 2005 | 08:03 PM
subford's Avatar
subford
This is Duraspark II wiring:
https://www.ford-trucks.com/user_gal...oid=30751&.jpg
Old Sep 1, 2005 | 08:56 PM
neoflee's Avatar
neoflee
yea it is tfi , because ive already replaced the eec
ki4iua
114
Dec 13, 2023 03:16 AM
Nimrod.sixty9
29
Mar 29, 2023 04:08 PM
Dirtydan1213
Jul 4, 2017 03:01 AM
kjs5055
Nov 10, 2016 04:22 PM
Rackpatrol
Aug 2, 2009 10:47 PM
