1978 - 1996 Big Bronco
Weird Idle on start up
Old Aug 29, 2005 | 01:18 AM
GreatWhiteBronc's Avatar
GreatWhiteBronc
My brono idles very oddly right when i start it up. The idle goes straight to 1200rpm for about 5 seconds, then up to 1500 for about 5 seconds, and then down again. It repeats this cycle until i rev the engine, at which point it rests at it's normal idle very steadily and then proceeds to drive great. Thanks for the help!
Old Aug 29, 2005 | 01:41 AM
ford390gashog's Avatar
ford390gashog
what year? i assume it has a carb in which case it is called the fast idle and kicking it down is normal. you can set the fast idle too.
Old Aug 29, 2005 | 01:52 AM
GreatWhiteBronc
Its actually a 93 bronco, no carb.
Old Sep 2, 2005 | 03:17 PM
hambeemer's Avatar
hambeemer
fuel pressure regulator. sits under the intake manifold area. shiny thing with a vacuum line attached to it.
