4R100 shifting problems
Old Aug 28, 2005 | 09:22 PM
017.3's Avatar
017.3
I have a 2001 psd f-350 and it started to not shift correctly. It wouldn't shift out of first while under acceleration, but if you let off it would shift fine. The low clutches were black the intermediate friction clutches were gone and my drive and o/d clutches were black also. It was also running hot 200-300 deg for obvious reasons. So i rebuilt my tranny and put in a transgo tugger kit and a .427" pressure modulater in it. Now it doesn't want to shift until it almost redlines the motor then when it does shift it doesn't know what to do. it feels like it goes from 1st to drive then downshifts back to 2nd and if you accelerate to much it will downshift back into first at redline rpm's and start the shifting process all over. If i shift it manually it does fine until i put it back in drive. any help would be appriciated. I reset my computer after i rebuilt it, also my o/d light still flashes sometimes.
Old Aug 29, 2005 | 08:05 AM
Casey's Avatar
Casey
Did you replace the mechanical diode with the sprag type one way clutch? The mechanical diode was most likely the source of the original failure. If it's still in there it needs to come out.
Old Aug 29, 2005 | 12:11 PM
017.3's Avatar
017.3
Yes i took the mechanical diode out when it exploded at 36,000 miles and the sprag fell apart when i took it out this time so i installed a heavy duty sprag. I'm wondering if one of the sensors or the solonoid pack might be going out. It doesn't want to shift under power and when it does shift it doesn't know what gear to go into.
WB4IUY
Oct 6, 2014 07:33 AM
Gribbletyler
Bronco II
Mar 23, 2012 09:06 PM
mwistrom
Aug 26, 2009 07:23 PM
Merculous
1997 - 2003 F150
May 21, 2006 06:17 AM
017.3
Sep 1, 2005 11:11 PM
