Sponsored by: Auxito
On acceleration, a short vibration
Old Sep 9, 2005 | 01:27 PM
ColonyPark's Avatar
ColonyPark
Also, I set up a service appointment at my Ford dealer for this problem. It's a week away, but if no one else gets a fix by then, hopefully I'll be able to get an answer about it from Ford. The problem described by everyone sounds like the same problem.
Thanks!
Old Sep 9, 2005 | 08:45 PM
Racerguy's Avatar
Racerguy
I would start by pulling the rear driveshaft out and checking the u-joints to see if they move smoothly. You can't always tell with the driveshaft installed.
Limited slip problems usually only show up when going around a corner.
Like was also mentioned I would lube the inside of the splines in the slip yoke at the front of the shaft. Ford makes Teflon grease for this but any good grease will work enough to prove whether that's the problem or not.
Old Sep 20, 2005 | 10:08 PM
ColonyPark's Avatar
ColonyPark
Well, this problem is fixed for me. It was indeed the clutches in the axle. The dealer replaced them today. The odd thing was that the shudder would even occur with the vehicle going straight ahead. The van only has 19,500 miles, so I guess that there was a mechanical breakdown of some sort. Hope this helps others with the same problem.
Old Sep 21, 2005 | 08:00 PM
Chuky66's Avatar
Chuky66
thanks for the update!!!!!! We'll look at that!!!!!!!!!!!!
Chuck
Old Oct 5, 2005 | 06:57 PM
Kong1965's Avatar
Kong1965
How did it work Chuky66?
I'm getting exactly the same thing, and I'm getting an odd clicking/pinging sound at the same time. Thought it was the engine first (I've been through the COP/Plugs routine, with therapy I got better), but can't reproduce unless vehicle is moving. U-joints are all good. Place vehicle in gear, but hold brake and rev = no clicking or vibration. Start to drive, feels like I've got a plug missing, but no check engine light.
Clicking is more pronounced during turns from stop. Vibration never completely goes away.
I have locking rear diff and 4x4.
Let me know how it goes.
Old Oct 5, 2005 | 07:05 PM
Racerguy's Avatar
Racerguy
Hi Kong and welcome to the forum
Did you remove the driveshaft to check the U-joints? Sometimes they can fool you unless you do. You might have a seized joint.
Old Oct 6, 2005 | 02:19 PM
78 short's Avatar
78 short
Most peaple that have that same problem over look putting some friction modifier in there diff.They need some added every once and a while.It cures all kinds of rear end vibrations and noises.It's also cheap.At least try it before spending more time and money.Unless you don't have a posi diff.I do work for my local municipality and have seen just this month four of our ford trucks with 8.8 diff with faulty rear diff bearings and factors settings that caused the diff's to go bad in under 50,000km's.Hope that's not your problem.If it is do yourself a permenant fix and buy the carrier assembly for 350.00 dollars.Because the factory one is junk and rebuilding it might not cure it for long.Just what I've seen here.
Old Feb 10, 2006 | 04:33 PM
TEKWS01's Avatar
TEKWS01
I have this same symptom on my 2000 5.4 f150.. This vibration is auditable and not a vibration that is felt. at this time it is at a tranny shop and the tech thinks this is caused by a convertor coming apart.
Old Feb 10, 2006 | 05:09 PM
Racerguy's Avatar
Racerguy
Hi TEKWS01 and welcome
When do you notice the problem? What speeds? Turning?
Old Feb 10, 2006 | 05:28 PM
TEKWS01's Avatar
TEKWS01
Thanks Racerguy.. The vibration noise will manifest just after take off while going straight. vibration noise seems to be related to drive line load. Noise can be duplicated at a slow constant speed by manipulating the gas pedal. If load is very light. vibration noise is heard. but if I accelerate slightly noise will go away. and if I decelerate, the noise will go away. additonally the overdrive light is flashing a code and the tranmission tech has found debris in the oil pan. which he thinks are damaged convertor parts.
Old Feb 10, 2006 | 08:56 PM
ColonyPark's Avatar
ColonyPark
That's really different from what I experienced, and mine turned out to be the clutch packs in the axle. Sounds like you have major transmission trouble...
Sorry
Old Feb 11, 2006 | 10:21 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
on my 00 4x4 there is no slip yoke on the drive shaft, its all part of the output on the transfer case
Old Feb 12, 2006 | 08:25 AM
  #28
shivelyt's Avatar
shivelyt
tom
My 99 has the same symptoms. I've tried every remedy. called mechanics, had it checked out by mechanics, checked things myself, replaced u-joints,greased yoke, unhooked emergency brake cable, serviced tranny, added inti-shudder additive, balancing tires. Spent hours reading posts. etc,etc,etc. I learned to ignore it after a couple hundred dollars and countless hrs. I hope you can find something. Let us know.
Old Feb 12, 2006 | 09:17 AM
  #29
ColonyPark's Avatar
ColonyPark
I assume you're referring to the symptoms of my van that started this thread. Mine was cured completely when the dealer replaced the clutch packs in the trac-loc axle.
