Sponsored by: Innova
Using both top and side posts on a battery
Old Aug 27, 2005 | 10:44 PM
mcjones44us's Avatar
mcjones44us
Hey everyone;
After gradually adding on different accessories to my truck I've now got a nest of assorted wires running to both + and - terminals of my batteries; everything from 1/0 amp cables to 16 guage wire for accessory lights & such.
I'd like to clean up my mess. I've got optima yellow tops which have both top posts and side connectors. Can I use the top posts for the battery connectors and also use the side posts for accessories?
If anyone else has any hints/tips or pictures of a nice looking electrical under-the-hood setup, I'd love to see them.
Thanks!
Mike
Old Aug 28, 2005 | 02:52 PM
fordboy_52's Avatar
fordboy_52
yes u can
Matt
Old Aug 28, 2005 | 02:57 PM
ford390gashog's Avatar
ford390gashog
yes its fine.
Old Aug 28, 2005 | 10:07 PM
RomerB2's Avatar
RomerB2
To clean up the mess you can zip tie wires together, then put on an electrical sleeve over a little bunch of them that kind of makes them disapear. Doesn't cost much money either ~$5.
Old Aug 28, 2005 | 10:59 PM
mcjones44us
Thanks for the feedback folks.
Old Aug 29, 2005 | 01:57 AM
RomerB2's Avatar
RomerB2
Your welcome, glad to see we may have helped!
Old Aug 29, 2005 | 02:40 AM
MemOrex's Avatar
MemOrex
Instead of running wires back to -, why dont you just ground them on metal?
Old Aug 29, 2005 | 03:29 AM
RomerB2's Avatar
RomerB2
I just noticed that.. for one, ground should be kept relatively short, and two it will clean up your compartment quite a bit. Just make sure it's a clean ground no matter what you're grounding.
